RE: Painting 1 - 2 -3
Leroy... I've run into an issue... I'm using the DupliColor high fill primer (as directed). 3 coats, 10 minutes apart, wait an hour and then dry sanded with 220 and then wet sanded with 400.
next day I put on 3 coats of sandable white primer... it looked terrible. did not cover welll at all... I wet sanded most of it off. The resulting surface is highly polished but a mix of the ruddy red from the highfill primer and white streaks from the second primer.
do I paint on that?
DupliColor Ford Blue and Ford White.
