ORIGINAL: hwheelman
Hello,
As I have said before, this is a great thread!!!! I have a question on my wing after getting completely together (not sheeted) I have nticed when you turn wing right side up and look at the angle from center, that the measurement at the wing tip down to the table is off by aprox 1/4 of an inch one side to the other. Can anyone tell me if I have really srewed this up or what????Was so careful and still ended up off and its enough when you get down and look at it straight on you can tell. Very frustrating especially when you are ocd about things!!!!! Thanks for any input!!!!!
The angle you are referring to is called the dihedral angle.
The 1/4" difference will not affect the model behavior. The wing can still be installed so it is the same distance to the horizontal when assembled.
Zor
