RCU Forums - View Single Post - E-flight 160 for a Brio ??
Old 04-02-2013 | 05:55 AM
DrMotor
Default RE: E-flight 160 for a Brio ??
This is just my own opinion: For a 2m F3A plane like the Brio:
a. My first choice would be: Turnigy F3A SK3 Competition Series 28 Pole Outrunner, 590g, Kv 240; $139.15
<span style="font-size: small">-This is basically the same 28 pole motor asa Hacker A60-20 S V2,Kv 245
</span>
b. My second choice (in USA)would probably be: Torque F3A "Silver Bullet", 580g, Kv 220, 28 pole; $225.
OR:Shulman Aviation FURY 60/67-230 "F3A", 590g, Kv 230, 28 pole $225
(they are both the same, apart from a small Kv difference -http://www.rcuniverse.com/forum/fb.asp?m=11458640
<span style="font-size: small">-This is because they are bothbasically the same 28 pole motor as a Hacker A60-22 S,Kv 217 (Torque);orA60-20 S, Kv 245 (Shulman Fury)
</span>
c. If in Europe, my 2nd choice would probably be: LiPolice LPA-F3A-5030-210KV, 580g, Kv 210,28 pole, $218
This is basically the same motor as the other three ...and is alsomade in the same Sunray factory as the other two ...
-And will have identical internal parts to the other three
And will have an identical performance to the other three ...
<span style="font-size: small">-It is basically the same 28 pole motor as a Hacker A60-22 S, Kv 217 </span>
