RCU Forums - View Single Post - F3a The Future
Thread: F3a The Future
Old 04-02-2013 | 04:38 PM
  #196
drac1's Avatar
drac1
Default RE: F3a The Future
ORIGINAL: smcharg
ORIGINAL: TimBle
That places the liquid fuel aircraft at a disadvantage so its not a good idea.
The liquid fuel aircraft needs a heavier airframe and its take off weight will be greater than 5050gr. This proposed rule change will result in even more expensive airframes which seems counter intuitive
<br type=''_moz'' />
Respectfully disagree to your point. Look what MTK has managed, look what CPLR has managed with glow, look what Bryan Hebert manages with even the new Shinden. Even so, the point is if the weight is increased, no one is at a disadvantage or advantage. Heavier does not fly better. The goal will still be to keep your weight down. If the weight is set at 5500g per the proposal and the glows weigh with fuel, they will be at 5200-5300g. They will have 200-300g room. The electrics are able to carry higher capacity batteries (which is absolutely of no advantage in a competition) and certainly allows them to be competitive when the winds are very strong and a pilot flies bigger which ultimately requires more energy. Bryan Hebert told me just the other week that the nice thing about glow power is that as long as there is fuel to the engine, the engine develops the same amount of power take off to landing. Electrics are already at a disadvantage as the pack is depleted. Adding 200-300g will not change everything but certainly there is a little more room for the advancement of bipes and contras.
Many glow powered aircraft out there struggle to make the 5000g. Some electrics also. 5500g with fuel will still be a struggle for some. A YS170 glow will need a 500cc tank, putting the 5000g plane still on the edge. Therefore no benefit would be gained there. Using the YS cdi a 300cc tank can be used, which would be ok but not everyone uses a cdi.
