RCU Forums - View Single Post - E-flight 160 for a Brio ??
Old 04-02-2013 | 07:57 PM
DrMotor
Default RE: E-flight 160 for a Brio ??
Just a thought: If thinking about an E-Flite 160, why not go for the Turnigy G160 ?
-They are <span style="font-size: small">exactly </span>the same motor, and the G160 is half the price:</p>
Turnigy G160, 245kv, 649g, D63 L66 $72.31
http://www.hobbyking.com/hobbyking/s...160_Glow_.html</p>
Here are some user comments from the HK website:
" ... Fitted to Sebart 110 for advanced schedule, the power train is . . . G160, 100HV ESC, 10S2P 5000mAh. At 1500m altitude:
turnigy 17x10 @55 amps = 4.5 Kg thrust
apc-e 18x10 @55 amps = 5.0 Kg thrust
apc-e 19x10 @55 amps = 6.0 Kg thrust. ..."
</p>
"<span style="font-size: small"> ... This motor is visually almost identical with Axi 5330 and Power160 as well ..." </span></p>
" ... Use it on 120 class 81in' TBF, with graunper 16*8 3 blade prop, 2 6S 4000mah 20C for 12S, TURNIGY Sentilon 100A HV 5-12S
60A, 2952W at max output. It's comes with nearly 8000g thrust. I love it! ..."
</p>
" ... Great motor! 100A ESC, 10S 4500Mah (25C) with 19/10 wood prop draws 60A and 2450W, with 16/8 3-blade prop draws 48A with 2100W. Motor barely gets warm. Great torque and power! ..."</p>
No-one seems to have reported when using a typical F3A prop -but this motor will perform identically to the E-Flite 160 ...
See: http://www.rcuniverse.com/forum/fb.asp?m=11466598 posts #136 and #137
Pic shows: 1,2, The G160 looks <span style="font-size: small">identical</span> to a Himax motor, to a TopModel X-Power motor, and to an AXI motor ...
Pic 3 shows the E-Flite Power 160 has the same backplate as the G160 -they are probably the same motor, made in the same factory ...
</p>
ID:	1869638   Click image for larger version
ID:	1869639   Click image for larger version
