RCU Forums - View Single Post - Cockpit SRS help
Old 04-05-2013 | 08:31 AM
Colin Gontier's Avatar
Colin Gontier
Default RE: Cockpit SRS help
Alex,
You may have done this already but one thing worth noting is that the sequencer / gear channel does not work when you are in programming mode so you have to go make sure you are in normal operational mode to use it. In the latest software I seem to remember there is a test mode that operates by pushing the buttons so you can check your sequencing.
regards
Colin
