 Cockpit SRS help >
Cockpit SRS help
Cockpit SRS help
Old 04-05-2013 | 06:45 AM
Alex48's Avatar
Default Cockpit SRS help
Hi Guys
Ive programmed a sequence for the gear and doors but I cant get my gear switch to actuate it. If I move the gear channel to any other socket it works. I cant get Channel L to do anything. I'm I missing some thing?
Cheers
Old 04-05-2013 | 07:33 AM
mick15's Avatar
Default RE: Cockpit SRS help
Alex, if you go to the PB site you will find a Firmware upgrade for the Cockpit in which there is a setup Wizard.
Makes the whole job much easier.
m
Old 04-05-2013 | 07:47 AM
Alex48's Avatar
Hi Mick
I dont have the correct lead to update the PB I just have the one that comes with the igyro which is normal servo plug
Old 04-05-2013 | 07:53 AM
mick15's Avatar
Thought they were the same, does it not plug into the side of the unit?
m
Old 04-05-2013 | 08:05 AM
Alex48's Avatar
hmmm theres no picture in the instructions I found a 4 pin socket on the right side by the switch socket.
Old 04-05-2013 | 08:22 AM
Alex48's Avatar
hang on think Ive found it be useful to have a picture in the instructions for idiots like me... Now I just need to find the update option in the menus which is currently eluding me. lol
Old 04-05-2013 | 08:31 AM
Colin Gontier's Avatar
Alex,
You may have done this already but one thing worth noting is that the sequencer / gear channel does not work when you are in programming mode so you have to go make sure you are in normal operational mode to use it. In the latest software I seem to remember there is a test mode that operates by pushing the buttons so you can check your sequencing.
regards
Colin
Old 04-05-2013 | 09:33 AM
Alex48's Avatar
Hi Colin
I can get it to work in test but not out of the set up mode. I can even get a servo to operate out of the L socket, hopefully figure out how to update it nd all will become clear.
Old 04-05-2013 | 10:27 AM
I have one that I tried for days to get the sequencer working. I finally have up on it and went a different route. I wish you better luck!
Old 04-05-2013 | 10:38 AM
Alex48's Avatar
Thanks...
The new update has an install wizard but I cant work out how to update the cockpit, the computer software just says no device connected! I hate computers
Old 04-05-2013 | 10:41 AM
Alex48's Avatar
I dont think my cockpit can be updated as its not version 12 but has to be sent back to powerbox
Old 04-05-2013 | 11:06 AM
madmodelman's Avatar
Ii had to send my Comp SRS back also Alex, pia.
Old 04-05-2013 | 11:15 AM
Alex48's Avatar
Shame as need it for a test flight... Ill have to lose a channel and sequence the gear through the transmitter...
Old 04-05-2013 | 11:52 AM
Alex48's Avatar
Finally, I've got the sequencer to work!
Once I got my head round it it works very well and is very versatile, I had the end points in the cockpit wrong so the first valve wasn't actuating.
It only took half a day
