<span style="font-size: medium">CONT:
</span>9. <u>SO: <span style="font-size: small">WHAT IS A "GOOD" OR "BEST" PROP TO USE FOR THIS 150g 1000Kv MOTOR ?</span></u><span style="font-size: small">
</span>a. The results of this test suggest that on 3S LiPo, a 12x8 or a 13x6.5 prop might well be best for this motor. On 3S LiPo, the 12x8 gave 1.72kg (=1720g) of Thrust for 38.2A; The 13x6.5 prop also gave 1.72kg of Thrust, but for 39.5A.</p>
b. On 4S LiPo, the 13x6.5 looks the best. It gave 3.015 kg of Thrust for 69.2A, whilst the 14x85 prop gave hardly any more Thrust, but required 77.2A.</p>
c. On 4S LiPo, the 15x8 prop gave less Thrust than the 13x6.5, for about the same current draw.</p>
10. <u><span style="font-size: small">APPLICATIONS OF THIS MOTOR:
</span></u>AeroModel state:
"The New A30 V2 series motors are designed for Larger Parkflyers, 3D-Aerobatic, Scale models and Helicopters using 2 to 5 series LiPoly batteries " -
https://www.aero-model.com/8_66/Moto...30-Series.html</p>
a.. <span style="font-size: small">AEROBATIC PLANES:</span>
A 150g motor like this Hacker A30-12 L would typically be used in Sebart 30-size planes (~1.3m wingspan) which have a 1.4kg flying weight -
http://www.sebart.it/30E-class.html
Similar planes to this are 3D Hobby Shop 48” wingspan planes -
http://www.3dhobbyshop.com/3D-Aircraft_c_189-1-1.html
or: Extreme Flight Vanquish, Precision Aerobatics 50” wingspan planes which have a flying weight 1.2kg to 1.4kg.
In planes like this, this Hacker motor on 4S LiPo will give these planes a 2:1 Thrust to Weight ratio. -Now, that is
<span style="font-size: small">fun</span> ...</p>
b. <span style="font-size: small">SLOWER FLYING PLANES and SAILPLANES
</span>This 150g 1000Kv motor can be used in slower flying planes and scale-type planes -probably up to ~1.6kg with 3S LiPo, and up to ~2.5kg with 4S LiPo.
For sailplanes: Esprit Models make some recommendations -
http://www.espritmodel.com/hacker-a30-12l-motor-v2.aspx -and suggest that this motor might be suitable for a 2m sailplane like the Great Planes “Spirit ARF” which has a flying weight of ~1.2kg. They suggest a 12x6 folding prop.</p>
<span style="font-size: medium">BEST PROPS for this motor:
12x8 on 3S LiPo
13x6.5 on 3S LiPo
13x6.5 on 4S LiPo
</span></p>
