RE: Hacker A30-12L vs Turnigy SK3 3542-1000Kv -Head to Head PERFORMANCE TEST
<span style="font-size: medium">CONCLUSION OF OUR INVESTIGATION.</span></p>
<span style="font-size: small">1. The Hacker A30-12 L motor is the EXACT SAME IDENTICAL MOTOR as the Turnigy SK3 3542-1000Kv motor.</span></p>
2. The Hacker motor might be be purple on the outside, and have a different style rear housing, and have a hub prop adaptor which attaches with 4 bolts rather than 3.</p>
3. However,features such as this are <span style="font-size: small">purely</span> cosmetic; -And nothing more. Cosmetic features like this have NO effect on motor performance.</p>
4. <span style="font-size: small">On the INSIDE, underneath the outer case, </span><span style="font-size: small">the Turnigy SK3 and the Hacker motors are COMPLETELY IDENTICAL.</span></p>
5. Under the same conditions on the Test Stand, the Hacker A30-12 L and the Turnigy SK3 3542-1000Kv motors give identical readings for current, power, RPM and Thrust,
-This proves unequivocally, and beyond a shadow of a doubt, that the Turnigy SK3 3542-1000Kv and the Hacker A30-12 L are actually the EXACT SAME IDENTICAL MOTOR, as far as the internal working parts of the motor are concerned.</p>
6. <span style="font-size: medium">The Hacker A30-12 L motor costs $101.53 </span>-all over Europe (=£66.20 in Queen Elizabeth's currency ... ); and this Hacker A30 motor costs $66.99 in USA.</p>
7. However, <span style="font-size: medium">the completely identical Turnigy SK3 3542-1000Kv costs only $27.76 </span>from HobbyKing.</p>
8. <span style="font-size: small">The Turnigy SK3 3542-1000Kv and the Hacker A30-12 L are the EXACT SAME IDENTICAL MOTOR, in all important respects.</span></p>
<span style="font-size: medium">-However, the Turnigy SK3 is only 27% of the cost of the Hacker A30 motor
</span></p>
