RE: Info from Data Terminal after a shutdown
while it does sound like a pump it could also be a solenoid closing at high flow if plumbed in backward or anything between the pump and turbine, try disconnecting the tube from the turbine and test running the pump at various speeds and see if you see/hear a problem.
