RE: Info from Data Terminal after a shutdown
Oh I see now. It's my fault. OK. I'll do another test tomorrow and move the stick very gently and see if I get the same issue. Fairly sure I will.
But I'm just curious, you're inferring that moving the throttle too quickly will always cause this type of problem? I would have thought the ECU would control the acceleration of the engine regardless of how the user moves the stick.
