RE: metal control rod threading tool
Dear Geish:
Smitty is absolutly right. Do not ever try to thread a rod with a die. It will not hold up. However having said that it is very possible to thread the rod. Set up your control throws. Adjust as nesessary then solder the BRASS clevis to the rod you threaded. This will makle a very good connection. Best of luck.
