RCU Forums - View Single Post - 12-22R Problem
Old 04-15-2013 | 10:37 PM
Chessiegolf
Default 12-22R Problem
Can anyone out there help me please.
Yesterday I was checking a model after the winter layoff and initially everything was fine. Suddenly the red (battery) light on the soft switch illuminated and there was no drive to the servos. I checked the batteries, which appeared to be fine, but charged them both overnight anyway. This morning when I switched on I still got a steady red light and no servo outputs. Using the 'monitor' screen of Gigacontrol I can see the signal outputs alter as the sticks are twiddled, so don't suspect the transmitter.
The transmitter and receiver appear to be communicating as I can press the 'quick bind' button and get the sympathetic green flashes on the tx and rx before settling back to steady greens.
I've checked the flash codes in the instruction manual and while there are a number of variations listed, a steady red light is not one of them.
Does anyone have any suggestions please.
Thanks in advance
