RCU Forums - View Single Post - Evolution 58GT gas engine Ignition problem and CH Ignition conversion
Old 04-16-2013 | 02:37 AM
pe reivers
Default RE: Evolution 58GT gas engine Ignition problem and CH Ignition conversion
Nice sensor adapter. You may have to file a bit off the hub boss to get the timing late enough (rat tail)
Using the prop disks as drill guide is very easy to do if you have a drill press.
