RCU Forums - View Single Post - Hacker A30-12L vs Turnigy SK3 3542-1000Kv -Head to Head PERFORMANCE TEST
Old 04-16-2013 | 05:26 AM
  #72
siberianhusky's Avatar
siberianhusky
Default RE: Hacker A30-12L vs Turnigy SK3 3542-1000Kv -Head to Head PERFORMANCE TEST
"2. The Turnigy SK3 3542-1000Kv is lighter than the Hacker A30-12L
The Turnigy SK3 motor by itself weighs 141.1g. The hub prop adaptor weighs 10.2g. The two together weigh 151.3g.
The Hacker A30-12L motor weighs 150.3g by itself. The hub prop adaptor weighs 17.9g. The two together weigh 168.2g
So: The Turnigy SK3 motor is lighter than the Hacker, by 18g."
Be interested to hear how they can be exactly the same motor yet you posted the above quote
Turnigy 141.1g yet the Hacker is 150.3? Over a 1/4 oz difference yet they are exactly the same motor?
You yourself proved right there that there MUST be some differences between the two.
If they are exactly the same motor just branded differently then by rights they should weigh EXACTLY THE SAME AMOUNT, shouldn't they?
How do you explain the mystery 1/4 oz? That is a lot of weight when you're dealing with something this size.
Oh well can't argue with this kind of logic, I'm not that kind of crazy!
