RCU Forums - View Single Post - Cooling for Ignition Module/Box ? ?
Old 04-16-2013 | 10:50 AM
karolh
Default RE: Cooling for Ignition Module/Box ? ?
If it's the older version ignition which is very power hungry and which gets quite hot during use then it's best to have it in a position where it will get some cooling air. If it's the newer RC exl type ignition then it does not need any special consideration when mounting except of course to keep it away from direct heat from the engine/muffler.
