RCU Forums - View Single Post - Propeller mounting
Old 04-20-2013 | 05:21 PM
MajorTomski's Avatar
MajorTomski
Default RE: Propeller mounting
Normally the prop will not be the proper thickness to properly engage the two nuts if they sit in the hex shaped holders. I have tightened on nut against the bottom of the prop shaft threads. Push the prop hex on that nut. Place the flat washer OVER the hex indent on the front side then run down the second nut. Then if needed use the third nut as a jamb nut against the second nut.
