 Propeller mounting >
Propeller mounting
Propeller mounting
Old 04-20-2013 | 05:04 PM
Default Propeller mounting
Just got a ARF electric Cesna and I'm trying to mount the prop correctly. The instructions say %^&*^% or something like that! The motor shaft is threaded and the prop came with three nuts and one flat washer. The prop has indentations on both sides that recieve hex nuts. My question is, shoud I mount the prop with the nuts on both sides and into the indentations and a third nut outside with the flat washer between the nut and the prop? How much clearance should I have between the prop and the nose? Hope my questions are not as vague as the instructions. Thanks.
Old 04-20-2013 | 05:21 PM
MajorTomski's Avatar
Default RE: Propeller mounting
Normally the prop will not be the proper thickness to properly engage the two nuts if they sit in the hex shaped holders. I have tightened on nut against the bottom of the prop shaft threads. Push the prop hex on that nut. Place the flat washer OVER the hex indent on the front side then run down the second nut. Then if needed use the third nut as a jamb nut against the second nut.
