ORIGINAL: felker14
Any one have long term update on this engine? What would be good 3 blade prop (need ground clearance)?
Thank you
I think that Biela and Menz make an 18x12 3 blade woodie. I've not usedeither so I can't vouch for performance or sound.
Mezjlik has an 18x10 carbon 3 blader which I have used on my OS GT33. Works adequately...not quite enough prop tho. And sound was only average. A 12 pitch would be much better.
It might besimpler andless costly in the long runto put on a longer gear set that will handle the 20" props. If you need something lighter than most, I can help
