RE: replcement wing kit
Just a suggestion. I would move the landing gear to the fuse, just forward of the wing saddle. I use aluminum landing gear screwed in with nylon bolts. Break a bolt, replace it and fly again same day. I built a new wing for mine the same way Tom did. It failed the 'fly through the tree test'. Out poped a fuse with mostly wing stubs. That plane is still in flying shape. Just semi retired. I wore out 2 engines on that plane. Really great plane.
Edwin
