RCU Forums - View Single Post - EV5U Valve Programming Help!
Old 04-28-2013 | 10:09 AM
Harley Condra
Default RE: EV5U Valve Programming Help!
ORIGINAL: Jjet
Hey Todd or anyone that can help. I have the non digital ev5u air power valve.
1. Valve sometimes has a mind of its own. Turn on plane and it sometimes cycles the gear. I have to lift plane up and turn on switches to keep from damaging doors/ gear. Gremlins?
2. I went to try and reprogram the card but for some reason it skips the valve 1-5 feature no matter what I do.
3. It also leaks air only when the power is on. Shut the plane off and holds air no problem. I did try crimping air lines off 1 by 1 to see if it was a cylinder issue...still leaking from inside the valve.
James
Try binding the receiver to the transmitter with the gear switch in the down position.
