Hello and thank you to anyone that can help.
i have completed my first gas build and it is a treehopper and I have installed a DLE 30 with Walbro carb and electric ignition. Yes I an a noob
I am using a Spektrum DX7 with spektum AR8000 received
I have the throttle servo mounted right behind the firewall. The Electric ignition is about 3 to 4 inches away and under the plywood that supports the servos and fuel tank and about 8 inches away from the recieved that is in the back section. I do have the recieved close to the battery but I do not think this is a issue as none of the other servos jitter or move. See picture below. The ign wire does run out the firewall next to the throttle servo and the throttle servo wire i have run above the plywood and as far to the other side as possible. It is next to some of the kill switch wires but not touching. I can start the engine and keep it at idle but if i give it any throttle it wants to jump to full throttle and back down or it kind of jitters around unless i keep it at the lowest thottle settings.
So where and I going wrong? I have tried to mess with some of the wires to see if one of them in the back makes it worse or better but so far no luck. I have thought to move the thottle servo back behind the gas tanks and move this up but it will still be about the same distance away from the ignition but it would get it away from the ign wire. Anyone have better ideas? Or should i just put in a huge electric motor and not fool with the gas?
Dlvsm<br type="_moz" />
