RCU Forums - View Single Post - What do the restorers use...
Old 04-28-2013 | 04:41 PM
Charlie P.'s Avatar
Charlie P.
Default RE: What do the restorers use...
I use Titebond II and heat will soften it.  (Titebond II is polyvinyl acetate, The original Titebond is aliphiatic glue).  Heat will soften both.
Countilaw - there is a product made by Jabsco that will dissolve polyester/epoxy.resins.  Nasty stuff and you normally wouldn't get there with R/C.  It would take forever to get down into a seam, but it might save the day if a batch didn't kick properly when glassing a surface.
