RE: Possible radio electric ignition interference issue please help.
Jester,
Ok so if it is a Vibration issue and assuming the servo is fine ,as this is the second servo I tried, is there a particular servo that would be better suited for this location? Or am I just going to be much better off moving the Servo back away from the firewall where the vibration is not so bad or as viloent? Also if it is a vibration issue why doesn't it do it all the time or only at low end when I first add throttle from idle? When it gets above mid throttle it seems to be ok. I know that the vibration is worst at idle but gets better when I throttle up so I am not sure. If there is a Servo that is more immune to this let me know. Thanks again to everyone.
Dustin
