RE: Possible radio electric ignition interference issue please help.
To Dlvsm,
Keep that ignition module and receiver as far apart as you can. Put a choke on the ignition wire to the receiver. Eliminate as much metal to metal contact as you can. Check your servo.
But, most importantly, congratulations on your first gasser. Before you know it you will be flying 33% and then 40% and then.............
Just my opinion, gas is much easier. I fly gas giant scale, glow, electric and turbine. Don't let anyone discourage you!
Good luck!
