RE: Possible radio electric ignition interference issue please help.
1. The Ignition batery wire runs from the 2000MAh battery pack to the kill switch and then back doown under the gas tank to the ignition. I thought this could be an issue so I removed this and went straight from battery to ignition with no change. When I have the battery connected to the ignitino direct I did move the battery up in front of the received but there was still no change.
2. I have a ball connector that is plastic connected to a metal push rod that connects to the servo with a metal connector. this is only about 3 inches long and does not run along any wires. I am going to change this but I assumed that as long as the connector was not metal to the engine it would be ok. maybe not.
thaks for the help.
