RCU Forums - View Single Post - Possible radio electric ignition interference issue please help.
Old 04-29-2013 | 05:02 PM
  #34
All Day Dan's Avatar
All Day Dan
Default RE: Possible radio electric ignition interference issue please help.
That metal pushrod to the carb acts like an antenna regardless of any type of connector you use. It passes through a strong electromagnetic field that exists around the engine, ignition module and any other component of the ignition system. In fact, it is a better antenna than the one in your receiver because it is much longer and the field strength around it may be higher. Dan.
