RCU Forums - View Single Post - Step by Step Hitec Aurora Throttle Cut Programming
Old 04-30-2013 | 02:47 AM
Nick Burroughs
Default RE: Step by Step Hitec Aurora Throttle Cut Programming
Hi
I have had problems with throttle cut settings and then found your method. I tried this but still cannot get it to work.
All ok till step 13 where it goes wrong. Before I start should I set the throttle trim to its maximum or awat. I do not see any throttle movement when adjusting the throttle trim.
Can you help?
