ORIGINAL: Dlvsm
Interesting the arguments that i have started here. LOL So the most think it is not a vibration issue and it is interference. I guess I will just move the servo back behind the tanks and see if this helps. Still would love to know if there is a better servo. I was one post that the brand of servo could be an issue. I may try another brrand and see before I move things around. BTW the wires and stuff int eh back was a mess when I took the photo because I was trying to make it worse or better. I wdid have everything nicely orginized at one point. [img][/img] Thank you to everyone and I will let you all knwo if I figure it out.
DLVSM
I think its been mentioned but the first thing you want to check is that the plug cap is seated correctly. Then check the servo. Then make sure all of your connections are tight.
I hate to be blunt but there's everything ranging from wives tales to outright poor information floating around in this thread.
To be fair, there's also some excellent advice, sorry you have to go through so much chaff to find the wheat.
