ORIGINAL: sundogz
Thanks J, I'll be sure to check for that! These Turnigy's are lighter that those new HK brand 90A esc's. The HK is listed as 105g and the Turnigy's 32g. I haven't weighed them (don't have a small scale) but they feel more like 2 to 1 (half) instead of 1/3. Nontheless, they will be an improvement for this 24'' cat.
No worries mate, I was disappointed that it bit it and HK was a bit of a run around to warranty it. It was the lightest that I've had to date for sure, I actually had to add weight to balance it out with the small lipo setup for rapids.
I'm keen to see the cat cranking with the jet drives. Are you going to use two micro servos with a Y harness or a link and single servo?
