ORIGINAL: SprinklerTech
Robert, I have the same plans you do but there is no thrust angles in the engine setup. Does anyone else show any thrust angles? I doubt there is a manual for this plane either, anybody know of one?
Tim
Zero-zero on the engine thrust, 0 on the stab, 1/2 degree positive on the wing. The balance point on the plans is good. Contrary to today's preferred set-up, a tiny bit of positive incidence coupled with a CG that requires a small amount of forward pressure on inverted is the best set-up for these classics.
Glad to see the Vertigo thread alive again.
-Robert
