Oh man, I'm with Baracuda, with all this help you should sell the plane and start collecting stamps.
Where's CGretired, not one mention of it being complicated on page two, slacker!!!![:-]
To be serious your plane and it's gas engine is a great choice and no it is not complicated. I'm sure CGretired enjoys cutting his grass and weedwacking his weeds with his glow powered lawn care tools cause god knows small gas engines are too complicated for him.
Your install looks fine for someone who is doing it the first time and once you lick this one issue it will be clear sailing after that, and with zero cleanup.
So stick at it and make sure you lick it before it licks you.
PS Don't ty wrap the tygon fuel lines, they pinch and cause fuel/air leaks. Just cut off 1/4 inch from some spare tygon, use needle-nose pliers to spread it open and slide it over the end of the fuel line that gets pushed on to the brass fittings.
