RE: Hangar 9 P40B Warhawk 50
Opjose by chance are you able to take pics yet?<div>
</div><div>I have the Top Flite can muffler and header. The only forceivable way I can see doing this is using 2 90 degree elbows. Only issue is they would have to be awefully small elbows as the spacing between the end of the header and the edge of the motor mount is pretty small. Then I can use something like an automotive clamp to secure the can to the bottom of the motor mount which would mean cutting a couple slits on the bottom of the motor mount. I thought about using zip ties but figure they would melt. Other issue is sealing the elbows to the header and muffler can. Thought about silicone adhesive but don't know how it would react to the nitro fuel.</div>
