RCU Forums - View Single Post - A Long Time Coming
Old 05-05-2013 | 05:08 AM
  #33
JohnBuckner's Avatar
JohnBuckner
Default RE: A Long Time Coming
Now pretty well have the setup for wireless buddy system to use Hitec to Hitec Eclipse 7 Pro and up and also the Futaba to Futaba Square plug to Square plug versions that are 2.4.
The Futaba to Futaba system cost about 35 bucks and it works just as well as the Futaba system.
Now for the last combination experiment although with the two cords and Rx's above I have everything I need to take on both Hitec and futaba students and untilize the advantages of the wireless buddy, I did set up yet another cord (a total of three cords) that using the external battery, the FrSky Rx that allows Hitec to be used as the master and the Futaba 6EX to be used as the buddy box. This is a combination that I am not likely to use but I did test this and it also worked well.
The last picture shows the three cords and the two rx's that I ended up with:
John
ID:	1879311   Click image for larger version
ID:	1879312   Click image for larger version
