RCU Forums - View Single Post - HL-TIGER I, Basics, Failures and how to remove them.
Old 05-05-2013 | 10:20 PM
beppel's Avatar
beppel
Default HL-TIGER I, Basics, Failures and how to remove them.
Foreword:
Since I own my Tiger I, I did many modifications to this model. Why? Because there are so many failures comming with this model, that there is plenty to do to change it into a real good model.
I also figured out, that many people have the same problems with their Tigers without knowing the failures or even not knowing how to correct them.
One day, I made a deal with another german forum member. He sent me his Tiger, I corrected most of the failures and created a series of articles about each failure and how to remove it with simple work.
To find all the single articles, I created an index where I could list all the failures and link them with the single articles.
After discussing these possibilities in this forum, I decided to do the same for you guys.
This will be the mother of the articles, so please stick it somewhere.
To follow the articles, just push the links under the appropriate headline.
In the end, there will be a list of 32 steps to follow.
I cannot do all the article at once, so they will appear step by step.
Well, lets start.
What are we talking about?
We talk about an early HL-Tiger I as shown in the following pictures:
<u><span style="font-size: medium;">Basics</span></u>
How to open and remove the Tiger tracks
www.rcuniverse.com/forum/m_11502866/anchors_11502866/mpage_1/key_/anchor/tm.htm#11502866
How to open the Tiger
www.rcuniverse.com/forum/m_11502872/anchors_11502872/mpage_1/key_/anchor/tm.htm#11502872
How to remove the wheels
www.rcuniverse.com/forum/m_11502886/anchors_11502886/mpage_1/key_/anchor/tm.htm#11502886
How to increase spring tension
www.rcuniverse.com/forum/m_11502913/anchors_11502913/mpage_1/key_/anchor/tm.htm#11502913
How to remove the idler wheel
www.rcuniverse.com/forum/m_11503945/anchors_11503945/mpage_1/key_/anchor/tm.htm#11503945
How to remove the drive wheels
www.rcuniverse.com/forum/m_11503950/anchors_11503950/mpage_1/key_/anchor/tm.htm#11503950
How to remove / change gears
www.rcuniverse.com/forum/m_11503957/anchors_11503957/mpage_1/key_/anchor/tm.htm#11503957
How to remove and open the turret
www.rcuniverse.com/forum/m_11503962/anchors_11503962/mpage_1/key_/anchor/tm.htm#11503962
<u><span style="font-size: medium;">Chassis failures</span></u>
Missing tow bar
www.rcuniverse.com/forum/m_11504926/anchors_11504926/mpage_1/key_/anchor/tm.htm#11504926
Replace frontal "sparetracks"
www.rcuniverse.com/forum/m_11504934/anchors_11504934/mpage_1/key_/anchor/tm.htm#11504934
Missing transmission reinforcement plates
www.rcuniverse.com/forum/m_11504937/anchors_11504937/mpage_1/key_/anchor/tm.htm#11504937
2. Notek-rear light
www.rcuniverse.com/forum/m_11507090/anchors_11507090/mpage_1/key_/anchor/tm.htm#11507090
Wheels
www.rcuniverse.com/forum/m_11507100/anchors_11507100/mpage_1/key_/anchor/tm.htm#11507100
Missing lifting jack mount
www.rcuniverse.com/forum/m_11507125/anchors_11507125/mpage_1/key_/anchor/tm.htm#11507125
Tow shackles
www.rcuniverse.com/forum/m_11507133/anchors_11507133/mpage_1/key_/anchor/tm.htm#11507133
<u><span style="font-size: medium;">Hull failures</span></u>
Side mudguards
www.rcuniverse.com/forum/m_11511021/anchors_11511021/mpage_1/key_/anchor/tm.htm#11511021
Front plate
www.rcuniverse.com/forum/m_11511031/anchors_11511031/mpage_1/key_/anchor/tm.htm#11511031
Headlights
www.rcuniverse.com/forum/m_11511046/anchors_11511046/mpage_1/key_/anchor/tm.htm#11511046
Ventilation
www.rcuniverse.com/forum/m_11511056/anchors_11511056/mpage_1/key_/anchor/tm.htm#11511056
Antenna tube
www.rcuniverse.com/forum/m_11511058/anchors_11511058/mpage_1/key_/anchor/tm.htm#11511058
Antenna position
www.rcuniverse.com/forum/m_11511062/anchors_11511062/mpage_1/key_/anchor/tm.htm#11511062
Fire-extinguisher
www.rcuniverse.com/forum/m_11511066/anchors_11511066/mpage_1/key_/anchor/tm.htm#11511066
Tank periscopes
www.rcuniverse.com/forum/m_11511071/anchors_11511071/mpage_1/key_/anchor/tm.htm#11511071
<u><span style="font-size: medium;">Turret failures</span></u>
Gun mantlet and barrel length
www.rcuniverse.com/forum/m_11511969/anchors_11511969/mpage_1/key_/anchor/tm.htm#11511969
Barrel position
www.rcuniverse.com/forum/m_11512980/anchors_11512980/mpage_1/key_/anchor/tm.htm#11512980
Pistol hatch
www.rcuniverse.com/forum/m_11511979/anchors_11511979/mpage_1/key_/anchor/tm.htm#11511979
Observation slits
www.rcuniverse.com/forum/m_11512878/anchors_11512878/mpage_1/key_/anchor/tm.htm#11512878
Lifting points
www.rcuniverse.com/forum/m_11512890/anchors_11512890/mpage_1/key_/anchor/tm.htm#11512890
Turret center point
www.rcuniverse.com/forum/m_11512917/anchors_11512917/mpage_1/key_/anchor/tm.htm#11512917
Smoke discharger
www.rcuniverse.com/forum/m_11512896/anchors_11512896/mpage_1/key_/anchor/tm.htm#11512896
Commanders cupola
www.rcuniverse.com/forum/m_11512901/anchors_11512901/mpage_1/key_/anchor/tm.htm#11512901
"Rommel" storage box
www.rcuniverse.com/forum/m_11512985/anchors_11512985/mpage_1/key_/anchor/tm.htm#11512985
<span style="font-size: medium;">If you have a HL-Tiger 1 and did all the modifications, you will not have a scale model.
But after all this modifications, you have a model that really looks like a Tiger.
There are so many other technical things to do on the Tiger, even by adding accessories, it would be too much to show everything.
That&acute;s why I limited this one to the above points.
</span><span style="font-size: larger;">Greetings
Birger
</span>
