RCU Forums - View Single Post - HL-Tiger I: How to remove the wheels
Old 05-05-2013 | 11:13 PM
beppel's Avatar
beppel
Default HL-Tiger I: How to remove the wheels
Hi guys,
how can we remove the wheels?
Step 1: Remove the Tiger tracks
www.rcuniverse.com/forum/m_11502866/anchors_11502866/mpage_1/key_/anchor/tm.htm#11502866
Now check, wich version of wheels you have.
There are two possible versions:
1. version: Pluged wheels
2. version: Screwed wheels
Lets remove the plugged wheels first.
1. version: Plugged wheels
As you can see on the pictures, the first wheel overlaps the driving wheel. Remember that for reassembling.
First you have to remove the outer wheels. Just pull them of carefully.
Same procedure with the second line.
Now lay the hull on its back. Lets take a look onto the wheels from the bottom.
Take a small screwdriver and lift the wheels a little bit. Do it carefully to avoid the radial arm from breaking.
Now you can pull the axis carefully out of the radial arm. While pulling, push down the wheel to avoid the arm from breaking.
Same procedure for the inner wheels.
After removing the wheels, it looks like this.
Reassembling works the other way round.
Just consider, that the radial arms are now in basic position. To reassemble you need to rotate them against their spring motion until they fit with the feed hole of the axis. Then push the axis through the wheel until its body stop.
Screw of the screw until you can remove the complete wheel.
Remove screw from the wheel. Than you can disassemble the wheels.
Than srcew the wheels to the radial arm till body stop. Just make shure, that the wheels work easily after screwing. Otherwise just unscrew a little bit.
Greetings
Birger
For a lot more help with your Heng Long Tiger I tank, follow the below link ...
<font size="+1">HL-TIGER I, Basics, Failures and how to remove them.</font>
