 HL-TIGER I, Basics, Failures and how to remove them. >
Old 05-05-2013 | 10:20 PM
beppel's Avatar
Default HL-TIGER I, Basics, Failures and how to remove them.
Foreword:
Since I own my Tiger I, I did many modifications to this model. Why? Because there are so many failures comming with this model, that there is plenty to do to change it into a real good model.
I also figured out, that many people have the same problems with their Tigers without knowing the failures or even not knowing how to correct them.
One day, I made a deal with another german forum member. He sent me his Tiger, I corrected most of the failures and created a series of articles about each failure and how to remove it with simple work.
To find all the single articles, I created an index where I could list all the failures and link them with the single articles.
After discussing these possibilities in this forum, I decided to do the same for you guys.
This will be the mother of the articles, so please stick it somewhere.
To follow the articles, just push the links under the appropriate headline.
In the end, there will be a list of 32 steps to follow.
I cannot do all the article at once, so they will appear step by step.
Well, lets start.
What are we talking about?
We talk about an early HL-Tiger I as shown in the following pictures:
<u><span style="font-size: medium;">Basics</span></u>
How to open and remove the Tiger tracks
www.rcuniverse.com/forum/m_11502866/anchors_11502866/mpage_1/key_/anchor/tm.htm#11502866
How to open the Tiger
www.rcuniverse.com/forum/m_11502872/anchors_11502872/mpage_1/key_/anchor/tm.htm#11502872
How to remove the wheels
www.rcuniverse.com/forum/m_11502886/anchors_11502886/mpage_1/key_/anchor/tm.htm#11502886
How to increase spring tension
www.rcuniverse.com/forum/m_11502913/anchors_11502913/mpage_1/key_/anchor/tm.htm#11502913
How to remove the idler wheel
www.rcuniverse.com/forum/m_11503945/anchors_11503945/mpage_1/key_/anchor/tm.htm#11503945
How to remove the drive wheels
www.rcuniverse.com/forum/m_11503950/anchors_11503950/mpage_1/key_/anchor/tm.htm#11503950
How to remove / change gears
www.rcuniverse.com/forum/m_11503957/anchors_11503957/mpage_1/key_/anchor/tm.htm#11503957
How to remove and open the turret
www.rcuniverse.com/forum/m_11503962/anchors_11503962/mpage_1/key_/anchor/tm.htm#11503962
<u><span style="font-size: medium;">Chassis failures</span></u>
Missing tow bar
www.rcuniverse.com/forum/m_11504926/anchors_11504926/mpage_1/key_/anchor/tm.htm#11504926
Replace frontal "sparetracks"
www.rcuniverse.com/forum/m_11504934/anchors_11504934/mpage_1/key_/anchor/tm.htm#11504934
Missing transmission reinforcement plates
www.rcuniverse.com/forum/m_11504937/anchors_11504937/mpage_1/key_/anchor/tm.htm#11504937
2. Notek-rear light
www.rcuniverse.com/forum/m_11507090/anchors_11507090/mpage_1/key_/anchor/tm.htm#11507090
Wheels
www.rcuniverse.com/forum/m_11507100/anchors_11507100/mpage_1/key_/anchor/tm.htm#11507100
Missing lifting jack mount
www.rcuniverse.com/forum/m_11507125/anchors_11507125/mpage_1/key_/anchor/tm.htm#11507125
Tow shackles
www.rcuniverse.com/forum/m_11507133/anchors_11507133/mpage_1/key_/anchor/tm.htm#11507133
<u><span style="font-size: medium;">Hull failures</span></u>
Side mudguards
www.rcuniverse.com/forum/m_11511021/anchors_11511021/mpage_1/key_/anchor/tm.htm#11511021
Front plate
www.rcuniverse.com/forum/m_11511031/anchors_11511031/mpage_1/key_/anchor/tm.htm#11511031
Headlights
www.rcuniverse.com/forum/m_11511046/anchors_11511046/mpage_1/key_/anchor/tm.htm#11511046
Ventilation
www.rcuniverse.com/forum/m_11511056/anchors_11511056/mpage_1/key_/anchor/tm.htm#11511056
Antenna tube
www.rcuniverse.com/forum/m_11511058/anchors_11511058/mpage_1/key_/anchor/tm.htm#11511058
Antenna position
www.rcuniverse.com/forum/m_11511062/anchors_11511062/mpage_1/key_/anchor/tm.htm#11511062
Fire-extinguisher
www.rcuniverse.com/forum/m_11511066/anchors_11511066/mpage_1/key_/anchor/tm.htm#11511066
Tank periscopes
www.rcuniverse.com/forum/m_11511071/anchors_11511071/mpage_1/key_/anchor/tm.htm#11511071
<u><span style="font-size: medium;">Turret failures</span></u>
Gun mantlet and barrel length
www.rcuniverse.com/forum/m_11511969/anchors_11511969/mpage_1/key_/anchor/tm.htm#11511969
Barrel position
www.rcuniverse.com/forum/m_11512980/anchors_11512980/mpage_1/key_/anchor/tm.htm#11512980
Pistol hatch
www.rcuniverse.com/forum/m_11511979/anchors_11511979/mpage_1/key_/anchor/tm.htm#11511979
Observation slits
www.rcuniverse.com/forum/m_11512878/anchors_11512878/mpage_1/key_/anchor/tm.htm#11512878
Lifting points
www.rcuniverse.com/forum/m_11512890/anchors_11512890/mpage_1/key_/anchor/tm.htm#11512890
Turret center point
www.rcuniverse.com/forum/m_11512917/anchors_11512917/mpage_1/key_/anchor/tm.htm#11512917
Smoke discharger
www.rcuniverse.com/forum/m_11512896/anchors_11512896/mpage_1/key_/anchor/tm.htm#11512896
Commanders cupola
www.rcuniverse.com/forum/m_11512901/anchors_11512901/mpage_1/key_/anchor/tm.htm#11512901
"Rommel" storage box
www.rcuniverse.com/forum/m_11512985/anchors_11512985/mpage_1/key_/anchor/tm.htm#11512985
<span style="font-size: medium;">If you have a HL-Tiger 1 and did all the modifications, you will not have a scale model.
But after all this modifications, you have a model that really looks like a Tiger.
There are so many other technical things to do on the Tiger, even by adding accessories, it would be too much to show everything.
That&acute;s why I limited this one to the above points.
</span><span style="font-size: larger;">Greetings
Birger
</span>
Old 05-05-2013 | 11:21 PM
From: Hemel Hempstead,Hertfordshire, UNITED KINGDOM
Default RE: HL-TIGER I, Basics, Failures and how to remove them.
Hi Birger, Thank you for a long overdue series, I am looking foreward to printing the complete article and keeping it for reference. shaun
Old 05-06-2013 | 05:52 AM
YHR's Avatar
YHR
Thanks for this. Very good so far, and this will be a great reference for new guys who have their first HL Tiger. I like the way you are updating this post with the links to the others making it easy to find the articles.
I would suggest you post this index thread in the FAQ section once you are done. Some of this stuff has been covered before, but the way you are going to be indexing this information will make this easier to follow then the earlier stabs at this.
Old 05-06-2013 | 06:47 AM
B.A.D.A.S.S.Force's Avatar
Since I purchased one late last year, over the last 6 months I have bookmarked numerous HL Tiger I threads on various forums, which when all are combined, contain a lot, if not most of the helpful or needed modifications for the tank. Still, it's very time consuming with information scattered about so widely in so many places. So regardless of whether most or all the information eventually contained within this guide can still be found somewhere else already, by scouring the internet, this will be a great all-in-one-place guide, &amp; much better alternative for many to use when working on their HL Tiger I tanks!
So thank you for taking the time to do an awesome job on this HL Tiger I help article &amp; index here on RCUniverse forums Birger, I have already bookmarked this thread, &amp; will definitely be using it when I start modifications on my HL Tiger I at some point later this year!
~ Craig ~
PS
Sorry, but I also just have to lol (or at least chuckle to myself) with your closing request, it's almost too funny to even imagine someone asking for help with the English language, who would even use the word "<span style="font-size: larger;">orthographical</span>" to describe the nature of the help they might require.
Old 05-06-2013 | 12:45 PM
FreakyDude's Avatar
This is a great list and should be stickied somewhere
Old 05-06-2013 | 09:28 PM
beppel's Avatar
Well, that word came out of Leo-Org by searching for the right word.
At least I try my very best.
Greetings
Birger
Old 05-06-2013 | 11:31 PM
beppel's Avatar
Ok guys,
the basics are done.
Could somebody please stick this thread?
Greetings
Birger
Old 05-07-2013 | 05:07 AM
YHR's Avatar
YHR
I have asked the moderator to make this a sticky
Old 05-07-2013 | 11:04 PM
beppel's Avatar
Hi guys,
I just added new threads.
Greetings
Birger
Old 05-08-2013 | 12:02 AM
Thanks, excellent work ... keep them coming!!!
~ Craig ~
Old 05-10-2013 | 01:31 AM
beppel's Avatar
Ok guys,
completed the chassis failures.
Greetings
Birger
Old 05-14-2013 | 12:11 AM
beppel's Avatar
Hi guys,
started to complete the hull failures.
Greetings
Birger
Old 05-14-2013 | 01:26 AM
Airbrushler's Avatar
pretty cool i'm learning some stuff here to so thanks for sharing i look forward to seeing more
Old 05-14-2013 | 02:07 AM
beppel's Avatar
Thanks.
Just completed the hull failures.
Greetings
Birger<br type="_moz"/>
Old 05-14-2013 | 11:29 AM
YHR's Avatar
YHR
Again thanks. Awesome collection of things to fix. A real good source of information.
Old 05-14-2013 | 11:53 PM
beppel's Avatar
Hi guys,
started today with the turret failures.
My question again, can somebody make this one a sticky?
Greetings
Birger
Old 05-15-2013 | 04:25 AM
YHR's Avatar
YHR
I sent an email to the moderator to try. Maybe we need a few other guys doing the same thing, Don't want to lose this post to the back pages.
Old 05-16-2013 | 12:12 AM
beppel's Avatar
Well,
almost done with the turret.
The most complicated part is next.
Greetings
Old 05-16-2013 | 02:20 AM
beppel's Avatar
Ok guys,
just finished the turret.
Greetings
Birger
Old 05-16-2013 | 04:08 AM
beppel's Avatar
Work is done.
Index is completed
Greetings
Birger
Old 05-16-2013 | 05:59 AM
YHR's Avatar
YHR
Great job. The forum thanks you. I especially enjoyed the feature on repositioning the turret. This is one mod I have not done, but I think I will pull my Tiger off the shelf and have a go at it.,
Old 07-08-2013 | 06:30 PM
YHR's Avatar
YHR
bump. This needs to be a sticky
Old 07-08-2013 | 06:36 PM
Heng Long tigers suck.
Go with Tamiya 56010 or 56018.
Old 07-08-2013 | 08:18 PM
YHR's Avatar
YHR
ORIGINAL: zzsql
LOL OH NOOOOOOOOOOOO
Old 07-08-2013 | 09:41 PM
ORIGINAL: YHR
ORIGINAL: zzsql
While the Tamiya kits are of very good quality, I agree with YHR here. 1st of all not everyone has a huge budget for a model. Secondly, Heng Long models provide VERY GOOD bases for upgrades and custom builds. For me, a Heng Long was my 1st tank. The legendary PanTiger for $89.99 from HobbyTron.com 7 years ago got me into the hobby because the massive price of the Tamiya was something I simply could not afford. For many of the guys here this is more than just a past time, this is a passion; this is art. We take a photo and or a video from history a replicate it in miniature. In a way, immortalizing that vehicle and crew forever; whether it be a tank or a halftrack or a jeep. Tamiya can, but really all other 1:16th brands provide a side of modeling that tamiya can't; and that's personal involvement. What I mean by that is tamiya has a great system and a very good layout with great electronics, but really the most you can do it add your own custom paint and weathering. With all models there will always be detail parts and some kind of upgrades. Other than that it's just an assembly process. In contrast, someone can take a heng long which needs work, home-make fixes and scratch-build what you don't have and you will appreciate the model more because you fashioned it with your own two hands. That's the drive of this hobby. Creating what doesn't exist and seeing it come to life and knowing that with your two hands you made that into what it is. Besides, there would be no point in all the wonderful electronic options like El-Mod, Benedini, the new Clark boards, the SLU, and other that are just coming on the market. I love tamiya ( I own a Tiger and a King Tiger) but I will never give up my heng longs because they are my work, my time, my sweat, and even my tears that have went into making that model everything I envisioned in my head.
