RE: Outer Limits Stepped Mono.
RPMYou typed to have turn fin parallel to rudder. Ok, does this also mean the length of turn below strut will be the same, so they will work together completely in unison. Also will the turn fin be vertical or 90 degrees to transom. Now if vertical, my guess that it would work the best. Also the turn fin should be the same width as rudder. Correct me if i'm wrong!
