ORIGINAL: Rob2160
ORIGINAL: Basil Yousif
I have the Futaba 12FG radio and I am trying to set it up to operate two servos on one rudder. One pulls while the other pushes. This is for the Great Planes Patty Wagstaff Extra300. I have them setup as Rudder and Rudder2 but when I set up the triple rates - even after designating them on the same stick in the Functions menu only one the Rudder on ch3 will work for triple rates. The other one just stays on full rates. I should have just gone with a pull pull setup but it's too late now.
The Ailerons and the Elivators work good with the Tripple rate setup no problem there but they are preset to work together in the initial setup.
Is it possible to connect them via the same channel and use an inline reverser if needed? Maybe not the answer you were looking for..
Actually you would only need a y harness if you go the 1 channel route.one would push on one side while the other would pull on the other side.
split elevator servos onthe other hand would need to move in the same direction on opposite sides,requiring seperate channels or
maybe using Hitec digital servos and program one to reverse. but he figured it out.
