RCU Forums - View Single Post - GP Waco?
Thread: GP Waco?
Old 05-08-2013 | 03:38 AM
  #1189
RJStrickJR
My Feedback: (97)
Default RE: GP Waco?
CPTTodd,
Thanks for the info. I contacted Tower Hobbies and they gave me the number to Hobico (217)398-0007. It took me a while to get through because of their buisiness hours but I finally talked to Chris and he said that a replacement gear and fearrings are on the way.
Iwent ahead and finished her up last night and got the ballance right. I had to mount the batteries in the fuse between the two cockpits. I lined it foam,wrapped 2ea 6V 2450mah NmH's and then made a removable hatch to hold them in there. That give a perfect spot to mount the rec. The 4.8 battery for the ignition is mounted in the tray above the engine with the ign box. I also mounted 3 switches with charge jacks in the front cockpit behind the pilot. The only thing mounted to the outside is the fuel dot.
