RCU Forums - View Single Post - WhiteTiger88
Thread: WhiteTiger88
Old 05-09-2013 | 05:11 PM
White Tiger88's Avatar
White Tiger88
Default RE: WhiteTiger88
oddly enough i put the alan wrench back in and i don't know why you are suddenly posting to flame me when you where fine with the return since you where fine with it. On the broken wire part however i had to fix a fair amount of them inside the tank along with pick hot glue off everything. But i fail to see how you flaming me does anything......... As you have offically turned me off EVER buying a used tank no mater how "good" of a deal i get.
ORIGINAL: PanzerAce
I still have ALL the emails that I sent you, specifcally the email where I gave you links to every upgrade part it had on it. If you had clicked on the lower hull link you would have seen it was not all metal. I stated it was the asiatam metal lower hull. Asiatam classified it as metal , though only reinforcement, when i bought it from Phil @ RCTankWars 3 years ago. There were no wires broken because I keep everything in check. In fact, that upperhull was still, other than the replaced recoil, in factory condition. No wires were moved other than the on/off switch so I could mount the IR port. And what was with cutting my speaker wires back into the speaker???? Had to throw it away. Also, those motors are just fine, I ran it 3 hours today with no problems. Everything functions perfectly, I can post a video if you want. I reconnected all the wires you just cut loose. I assume you lost my allen wrench that I sent that I cannot find. You also lost my microswitch for the gun recoil. Thankfully I have alot of parts "in stock" if you will. Also I would LOVE to know whats broken?, cause it doesnt look broken to me.
This is the link I have you in the email, I can post it as well. http://www.rctank.de/product_info.ph...jlaie3r1jsffb1 Clearly stated in the description ->
The body is in metal, only the sides are in ABS
we also add to this Body Metal Tow Shackles with Nuts & Bolts
Metal Suspension Arms, Metal Sprocket Hubs
Metal Mounts for Idlers, metal reinforcement at the front etc…
