I have seen this plane destroy aileron servos while doing a loop.
If you put this engine in this plane, I would recommend 2 servos per aileron.
This has nothing to do with the type or size of engine; this is all about prop pitch and max RPM.
An OS 1.60 with a 10 pitch prop will cause more problems than a DA50 turning an 8 pitch prop.
It's about the airspeed; not the horsepower.
