RCU Forums - View Single Post - Wing Strut Mounting help
Old 05-12-2013 | 06:13 AM
eddieC's Avatar
eddieC
Default RE: Wing Strut Mounting help
Yes, the 2-56 will be fine. Fitting the ball at the wing and fuselage will need some ingenuity as the threads are short, but can be done. There are probably hard points already there, you could just epoxy them on instead of using a nut. <div>
</div><div>N1edm's method will work too. More than one way to skin that cat!</div>
