RCU Forums - View Single Post - Changing bearings
Old 05-12-2013 | 07:14 AM
jaka
Default RE: Changing bearings
Hi!
If you heat the crankcase enough the rear bearing will just slide in (provided you have it mounted on the crankshaft).Bearings on our aluminium engines should not be pressed in!
