<p class="MsoNormal" style="margin: 0cm 0cm 10pt"><b style="mso-bidi-font-weight: normal"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Schweighofer Alpha Jet Project (Part 8)</font></font></span>[/b]</p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font face="Calibri"><font size="3">In the meanwhile you can see more, the project is running. The next step is gluing the torsion tubes with 5 minute epoxy.
</font></font></span></p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">After this Peter glues the mounting area of the rudder in the fuselage. Here it’s very important to keep the correct angle. Peter has mounted formers at the top and bottom section which straightens the tube.</font></span></p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">During glue curing times Peter has started the building of the wings and control surfaces.</font></span></p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">The building is similar to the fuselage. The wings are connected by 2 50mm Strongal tubes.</font></span></p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Here the basic preparations are finished and the parts can be assembled to get an impression of the size. Peter’s friend is 179cm tall.</font></span></p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">The next step is cutting and sanding of all these parts with beginning at the front part.</font></span></p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Regards,</font></span></p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Mario Walter</font></span></p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Modellsport Schweighofer</font></span></p>
<span lang="EN-GB" style="line-height: 115%; font-family: ">www.alphajet-projekt.at</span></p>
