ORIGINAL: turnnburn
I am using a JR 12x and Im not terrible but not real good at radio programming. I want to add crow to one of my jets. I would like to either slave the crow to the flaps so when the flaps come down the ailerons go up or possibly to the gear switch so anytime the gear switch is in the gear dn position the ailerons are up in ''crow'' position. I need help with the different ways of programming this. I have one aileron on channel 2 and one on ch 8. Flaps are plugged into 6 & 7 on the rx.. I tried a program mix and have one aileron going up and one going down when the flaps come down.
Do a search on RCU for programming "Crow" This guy made it so simple.
I fly a 9503,,, My flaps are on a 3 positon switch. At use 1/2 flaps for take off and when I hit full flaps for landing, that's when my "crow" comes in.
About 2 degrees of down elevator and ailerons come up about 3 degress. You might have to ajust your down elevator after your 1st flight to add or subtract to keep the nose level
Hope this helps
Hoss
