RCU Forums - View Single Post - What are my options for programming Crow ?
Old 05-14-2013 | 03:57 PM
rcand
Default RE: What are my options for programming Crow ?
ORIGINAL: turnnburn
I am using a JR 12x and Im not terrible but not real good at radio programming. I want to add crow to one of my jets. I would like to either slave the crow to the flaps so when the flaps come down the ailerons go up or possibly to the gear switch so anytime the gear switch is in the gear dn position the ailerons are up in ''crow'' position. I need help with the different ways of programming this. I have one aileron on channel 2 and one on ch 8. Flaps are plugged into 6 & 7 on the rx.. I tried a program mix and have one aileron going up and one going down when the flaps come down.
BVM website has a video and step-by-step instructions on how to do it. I have crow on my Ultra Flash and the flight mode switch moved to the flap swith. The advantage is you will be able to make aileron and elevator trim changes which will be remembered/saved for each of the flap positions.
