RE: Deployed flaps plane stalled and crashed
Also helpful is to work your way up to full flap deflection incrementally. You didn't say what plane this was, but let's say for example we're talking about a Super Cub. The scale SC had a max flap of 40 degrees, which is a lot. So if I were setting up a Super Cub's flaps, I'd start with 10 degrees and see how that worked. Chances are the plane will balloon a little but I shouldn't lose it. So then I'll program some elevator mix to compensate for the ballooning, starting with maybe 3% and adjusting from there. Next I go to 20 degrees with the understanding that I'll get more elevator compensation because the mix is based on a percentage. I'll adjust the elevator comp if I need to, then move to 30 and then the max of 40 degrees. It's really helpful to have a two position flap switch so you can test two different settings at the same time.
