RE: is it really that good? u can do
see this is the type of guy i don't like [:@]
becouse hes giveing false infomatin I HAVE NEVER SEEN A U CAN DO "KNIFE EDGE LIKE A CAMP"
the ones i've had and flown all had coupling issues .. all the issues mulit demional so it would require ailerion and elvator mix to fly a hands off knife edge and even then wouldn't really do it .. and it whould change its habbets going from flat out knife edge to alpha knife edge fade ...
also the plane didn't want to lay flat in a bender the plane's hor stab was weak as heck i blew if off with flutter a few times the stock control horns suck ass if you fly decent .. you'll bend them
the plane doesn't snap well the plane doesnt carrie speed for pop tops .. yes hte plane can hover and it's easy to hover and yes it does fly slow
but come on man don't say stuff just isnt true .... the plane DOES NOT KNIFE EDGE well
and hell i didn thave problem with land gear becouse i never daired to harrier land it or slam it down hard ...... i knew it wouldnt hold out
also the plane was funky going into a KE spin ..
