RCU Forums - View Single Post - pull start for airplanes?
Old 05-19-2013 | 06:18 PM
Charlie P.'s Avatar
Charlie P.
Default RE: pull start for airplanes?
Weight of the spool, line, handle and ratchet. If you make one with a slip-line you could save weight, but how do you thread the line in unless it's an exposed engine. And then there is the problem of a hanging line in your hand whipping around a spinning prop for a sudden, unpleasant handshake.
